Cam and heads magnum 360
joker_fly
Magnum 5.2
New questions
Wondering about cam and heads
If I use the stock heads (if not cracked)
Vs engine quest heads what will I lose hp wise
New cam in both theoretical applications
As I undersand I can run more lift with the engine quest heads but how much net gain will I recive over stock heads
Will eventually boost it to around 10-14psi but this is much later but if I'll get more out of the Engine quest heads I'll rather do that now when engine is out on stand
So what do you guys say
Stock non cracked heads vs engine quest heads looking for around 400hp non boosted
Also stock intake and a ported throttle body
Or is a new intake a must ? If boosting
J
joker_fly
Magnum 5.2
Is that a vote for eq heads ?
Side question what hp limits are there using the stock kegg intake ?
dapepper9
Iowa/Nebraska Border
5.9L V8
Keg will limit you to about 250-260whp without boost or nitrous. Trying to build power with factory heads is also a waste of time. 40cfm/runner out of the box with EQs. It's not that your can run more lift its that you can get more airflow through your runners. Engine Masters has shown good heads far outweigh a good cam
VLG6963
