Coating spark plug heat shields.
Mark C.
5.9L
Can the spark plug heat shields be pressed back in after removal. Was thinking of Ceramic coating them with a High temp coating.
Just a thought, not putting much into it.
Your thoughts?
Mark
dexter
Banned
Your thoughts?
Mark
Yes - it takes them getting lined up properly to do it.
Just put some anti-seize around them to make it easier.
dapepper9
Iowa/Nebraska Border
5.9L V8
Don't put em back in. You don't need them at all and they just impede maintenance and drop rust in the hole
M
Mark C.
5.9L
I believe I'm gonna loose them. Like the shields jsmith linked to. If I do anything at all. I'll keep an eye on the boots for awhile, after I tune it up, that's all.
M
Mark C.
5.9L
Left heat shields didn't mess with them. Changed out the plugs, cab, rotor and plug wires. These are the plugs I pulled out of the motor. 97000 miles 02 5.9 liter. Not too bad I don't think. Number one being top left corner of picture.
JURO
DAVISBURG, MI
2001 Sport.
1500 5.0 liter.
is this good advice? i removed mine as i was forced to, my socket would not fit on spark plug.
