Sterling
- Dec 20, 2016
- 24
- 0
- 2001 offroad
- Magnum 5.9
I have a 2001 5.9 with 167000. I need to replace the plenum gasket and valve seal seals because I'm burning oil. I'm sure the cat is probably clogged by now too. Not much in parts but hours of labor. The head gasket appears ok, at least passed the blue fluid test. Before I get started I'm going to check the compression. What would be the expected psi. If they are all close what would be the cut off before I just replace the motor? I know this is subjective but I'll take opinions
