Hollabakzach23
Hey everyone!
So I have a few things going on this evening.
1) today I had the check engine light come on which I figured was the 02 sensor since that has triggered a few times here and there but when I hooked it up to my code reader it said it was a misfire in cylinder 2. It came on this morning I think and and stayed on all day but the truck was ever sluggish or boggy at all which kind of confused me I checked the wire to make sure it was tight and I will pull the plug tomorrow when I et home from work to see what it looks like. I reset the code this even and drove a little bit around the neighborhood and it never triggered again which I thought was strange so this issue is really more of what precautions should I take as I keep y'all updated.
2) this is pretty minor to myself since its never caused many problems but I would like to get fixed. My reverse lights and my third brake lights aren't working. My brake lights on the tails work just fine but the high mount light is not working the cargo lights work just fine so I'm guessing the harness can't be toast but the brake lights won't come on. I could not locate a fuse for the third brake light but then again maybe I wasn't looking hard enough? As far as the reverse lights I believe I have read something about the neutral safety switch connected to the transmission that activates the reverse light? Can anyone clear this up for me or does anyone else have any other ideas? I have checked the fuses in the cab and all seems well.
