Ive been trying to replace my crank sensor for almost a week now. Im at wits end. My arms arent thin enough to reach through the following
Wheelwell above frame
Between frame and trans
Between firewall and head
The only place I can actually touch the sensor is while laying on top of the motor blindly finger banging the back of the engine.
Turns out the pcv pipe is preventing me from getting a tool on the top bolt of the cps. The ram manual actually tells the procedure on the cps is to remove egr and pipe. Great
Ive been going slow as to not break any bolts. I have the manifold bolts off but cant get the intake nut loose. I cant seem to fit any tools there to get good leverage on it. Does anyone know what size the nut is? Its larger than a 19mm wrench.
My thought is to get a wrench that fits, but am open to other ideas.
