Jessedavis82
- May 27, 2016
- 4
- 0
- 2002
- 5.9
My clutch fan went out on my 2002 5.9l. I've read some posts about converting to a 99-04 Grand Cherokee electric fan. Is the Grand Cherokee fan 19" that will fit in my orginal shroud? With the wiring I really dont mind it being on constant since I do a lot of idling, my truck is for work only I work in pipeline construction so I idle quite a bit and need AC cold on hot days in Texas. With that said I wanted to wire it up to run all the time when the truck is on. What size wire do I need to use and what size fuse?
Thanks
Thanks
