Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Emergency fuel cutoff switch?
This is a discussion on Emergency fuel cutoff switch? within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Sponsored By: Moe's Performance
Reply
Old 01-02-2017, 11:38 AM   #1 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default Emergency fuel cutoff switch?
So my '98 Ram 5.2 stopped running in the middle of the road on Christmas eve. It's getting spark, but not fuel. I sprayed some starter fluid into the intake and it started, so it's not getting fuel. I replaced the relay and the fuse looks okay, so I am thinking fuel pump. If it is, it's going to sit until spring because I am NOT going out there in 30 weather to drop that tank! Before I set it aside for the winter though I wondered i there was an emergency fuel cutoff switch somewhere. I know I ran into that on my Mustang and an old Grand Marquis I used to have so I thought it might have one...
Any thoughts or advice on doing this job?
Sponsored Ad
Register to remove this ad.
kdryan is offline   Reply With Quote
Old 01-02-2017, 11:57 AM   #2 (permalink)
sbarron's Avatar
Ram Year: 2013
Engine: 5.7 HEMI
Default
when you turn the key to "on", can you hear the fuel pump come on momentarily?
sbarron is offline   Reply With Quote
Old 01-02-2017, 02:14 PM   #3 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Fuel cutoff is controlled by the PCM through the ASD relay. I believe the ASD relay also cuts off power to the ignition coil. If you want to check and the problem still persists, in the underhood fuse block, swap the A/C compressor clutch relay and the ASD relay, they should be the same type.
Otherwise, your problem may be lack of fuel pressure from either a bad pump, or a bad pressure regulator. An easy way to check is to rent a fuel pressure test kit from a place like autozone and test fuel pressure at the fuel fail by the TB.
Old 01-02-2017, 03:08 PM   #4 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default
Got a new relay since there are about a dozen of the same thing on the truck. I figured if no joy, I would have a spare. No joy... Don't hear the fuel pump...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FX-R Retrofit Cutoff Too Sharp? russcrypto Exterior 2 10-18-2015 06:26 PM
TYC Projector Cutoff MelonFarmeR Exterior 6 08-17-2015 04:55 PM
AUX switch area near Emergency park? stevens Interior 7 09-11-2014 01:22 AM
Fuel economy switch mod?? Jenkins186 Engine & Performance 6 06-28-2014 10:01 PM
Fuel tank switch Pull Ya General Discussions 22 08-26-2013 03:14 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
