Engine harness help ?
Mikeyn23
I have a 97 Dodge Ram 1500 4x4 5.9 gas replaced the engine came with a harness but noticed there’s a broken plug that’s missing does anyone have a diagram of when’re all the plugs in the harness connect to there’s 2 wires it’s on the drive side of the motor by the ac compressor but I have the ac one plugged in and all the injectors there’s no other sensors so I’m trying to find out what it would connect to if someone could send me a diagram or where that all go would help thanks
dudeman2009
Magnum 360
no pics of a complete harness, but is that the coolant temp sensor plug? Or A/C high pressure switch?
M
Mikeyn23
No I have the coolant plug in and the ac plug it’s two other wires I’ll show you a pic of what I’m talking about the gray one is the ac line and the other two are the one I’m talking about
dudeman2009
Magnum 360
try to get a closer picture of the wires, or a description of the colors, one looks like a black/yellow wire, cant tell on the other.
