My engine on my 1999 RAM 1500 went out, sorta.
Cylinder 8 has zero compression. It still runs, but definitely runs rough. There is only 111K miles on it.
Anyways, I was considering just using this engine to teach myself how to either rebuild or replace. My experience is not that great. I have never done engine work before. Most I have done was replace the rotors, calipers, and brake lines.
After sitting in the garage for 2 months I was finally able to get an hour of time and removed the valve cover on the left side hoping I would see something noticeable. This is when I realized that I do not have the time to screw with trying to rebuild an engine (if I want to drive it within the next couple years) so I am looking into just either getting it replaced or replacing it myself.
My question is this...
How difficult is it to replace this engine? Should I look into a small block or long block? For someone who has never done this before would it be silly for me to even attempt? I am pretty mechanically inclined so I catch on to things pretty easily, but I'm just concerned that I'll do something that would screw it all up on accident.
Plus I want my damn truck running because I could really use it right now.
Money is an issue as well. I called around and to have a shop do it it would cost as much as the truck is worth, if not more. Roughly $3,200.
Any suggestions would be greatly appreciated.
Thanks a lot!!
Nick
Thanks a lot!!
Nick
