monroepops
Before tune up, truck ran fine. After changing wires, distributor, rotor and plugs. The truck cranks fine but when put in gear it shuts down quickly. Can someone offer me any suggestion Truck is 98-ram 1500. 5.2
yes rechecked wires, they're correct. Wonder could wires be off by one positionDoes it idle ok? You may have a plug wire crossed of something. I always do mine one at a time so I don't mix them up.
Sent from my VS835 using Tapatalk
Firing order is correct, I'll try advancing wiresAgree with Marciel, I'd give the wires another look. Did you change them one at a time or did you yank them all off at once and go from there? I remember back in the day when I started getting serious about doing my own wrenching. I changed the plug wires on my 4 cylinder Honda and noobishly pulled all the wires at once because I was absolutely sure that I'd put the new ones on right. Surprise surprise, I finished the job and the engine wouldn't fire for nothing. Looking at a diagram, turns out I had the wires "advanced" by one terminal on the distributor cap. Duh!
At least I got the firing order right, LOL.
