Ramman5428
- Oct 20, 2016
- 4
- 0
- 98
- 5.9 360 v8
I have a 98 dodge 2500 the head gasket blew a couple months ago I put new heads exhaust manifolds injectors spark plugs spark plug wires distributor cap and rotor throttle body spacer and thermostat in it since then I have a whistling noise that starts a couple seconds after start up and doesn't go away I've had it smoke tested and the intake sprayed with starting fluid and nothing I took the belt off to see if it was any of the belts and it was still there I'm at a loss anybody have any ideas???
