96dak99ramphil
- Jul 17, 2015
- 2
- 0
- 1999
- 318 5.2L
Has anyone figured this problem out i have a 99 ram and a 96 dakota both have 5.2l and both have long crank times ive changed fuel pump crank and cam sensors dis cap rotor button wires and plugs on dakota and stil has long crank i did leak test on injectors today on the ram and found to be leakin the pressure off i pulled injectors out of intake and found two could visibly see dripage out of so i put two new ones in did fine when i went to leave work and cranked good then after sittin a hour had long crank again im a mechanic and have never had any issues like this before and have tried so many things on the dakota i dont want to throw the money away again on the ram
