Lethalweapon100
Hey everybody. Truck is a 1997 Ram 2500 5.9 V8. The engine thats going in is either a 1995 or 1996, just another 5.9 V8 that I rebuilt.
When the rebuilt engine was out of the truck, both screws holding the dist. Cap snapped off. And then i broke off a drill bit in one of them. No matter, I removed it and stole the one off my 97 engine.
I installed the rebuilt engine in the truck and i installed the front timing cover, water pump, and harmonic balancer. I did this so I could use the marks on the balancer to find Cyl 1 TDC. However, theres 4 different marks on the balancer. 3 of those marks are cut about halfway through, and one is cut all the way through.
Which one is cyl 1 TDC? Also, all the rocker arms and pushrods are out so i cant watch the valves and feel the compression with my finger over the plug hole.
Thoughts? Advice? How do?
Sent from my SM-G920P using Tapatalk
