mbarnaby89
- May 3, 2015
- 1
- 0
- 1999
- 5.2 Magnum
I have a 1999 1500 Sport with the 5.2 Last month my fuel pump died so I had it replaced at a shop about a week later it started to have an issue. When the truck would sit for a few hours especially overnight it would have to crank for several seconds before firing. I took it back and they warrantied the pump at no cost however about a week or two later, same problem. I was told to check the regulator however it is part of the pump assembly not in the engine compartment like I'm used to seeing. I used a fuel pressure gauge and found that when I turn the key on, the pressure only jumps to about 15 psi and immediately drops, when I start the truck it holds steady at 50 psi and when I shut it off it drops back to 0 in about 10 seconds. I am really getting frustrated with this so I was hoping somebody had an idea for me. Please and Thanks.
