Hey guys I am planning to fix my Governor Pressure Sensor the code I am getting along with the check engine light is P1763 Trans code Governor Pressure Sensor Voltage Too High. I was told you have to switch the part out and it should be fine, I understand you have to drop the trans pan and then you take a block off the valve body with the 7/16 bolts and torx screws and then it just plug and plays from there? It doesn't downshift correctly when going up hills that are long distance and is slow to shift properly from 1st to second. 2001 1500 5.2 Sport 4wd any good places to get the part for a good price as well?
