Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Hard-starting when (really) cold
This is a discussion on Hard-starting when (really) cold within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
So, as much as I have done to winterize my truck, Iowa winter once again does it's damndest to make ...
Like Tree1Likes
Sponsored By: Moe's Performance
Reply
Old 12-17-2016, 03:31 PM   #1 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default Hard-starting when (really) cold
So, as much as I have done to winterize my truck, Iowa winter once again does it's damndest to make things as miserable as possible.
Here's the deal. If the temperature is around freezing, the engine starts no problem. However, if the temperature drops to the teens/single digits then engine will fire but die right away. If I start the engine while holding the throttle just a bit, it fires and runs just fine, but as soon as I let off the throttle, the idle fumbles and the engine dies. If I hold the idle high with the throttle for a minute or two and let off, the engine will idle just fine, though sometimes it will start fumbling between a few and several hundred RPMs.
If the engine is hot, it will start and idle without any problems at all. So the problem seems to exist as long as the engine is cold, but completely disappears (for now) when it is at operating temperature.
My first thought was the IAC, but I did replace the damned thing earlier this year.
It's negative wind chills and blowing snow for the rest of the weekend here, so there is no ****ing way that I'm crawling around under the hood fiddling with things now. I'd just like to start compiling a list of things to check when the temperature at least comes within a few degrees of the freezing point, though I might be waiting some time.
I hate Iowa winters...
Yaahmean313 likes this.
Sponsored Ad
Register to remove this ad.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, tuned by Flyin' Ryan, Hughes plenum repair, steering stabilizer, 4x4 Posi-Lok
Yeret is offline   Reply With Quote
Old 12-17-2016, 03:42 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Default
Do you think you might be suffering from a little bit of fuel system freezing?
Do you add any fuel system anti-freeze to your fuel, such as "Heet", in the winter?
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline   Reply With Quote
Old 12-17-2016, 03:44 PM   #3 (permalink)
crazy_luck's Avatar
Ram Year: 2013
Engine: 5.7
Default
Grasping at straws, but I did have a car do almost the same thing - turned out the coolant was starting to gel up and dragging the water pump too much, bogging the engine down; after a couple minutes, the coolant was no longer gelled and there was no extra drag. Just had to tweak the coolant mixture for colder climate and problem was gone.
__________________
2013 Ram 1500 Express - Snow&Go
2006 Charger Daytona - Show&Go
crazy_luck is offline   Reply With Quote
Old 12-17-2016, 03:56 PM   #4 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
Good info. I remember this happening to me in Wyoming now that you mention it.
I added a block heater and the problem went away.
__________________
MICHAEL
SUPER MODERATOR
Old 12-17-2016, 03:56 PM   #5 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
The only fuel additive that I occasionally use is Seafoam. I usually dump in a can when the temperatures start getting cold (Fall) and when the temperatures start getting warm (Spring).
Interesting thought on the coolant. I replaced mine earlier this year and whipped up a 50/50 mixture using distilled water of course. Perhaps I can pop the cap and take a look at it later.
__________________
Old 12-17-2016, 04:16 PM   #6 (permalink)
crazy_luck's Avatar
Ram Year: 2013
Engine: 5.7
Default
Typically, a 50/50 will suffice, but if there is still some air or a leak in the system, it could cause freezing. Also, depending on the antifreeze used, a 50/50 might not be correct. I'd get a simple tester from NAPA or some other parts store and test it.
https://www.napaonline.com/napa/en/p...1125/SER771125
__________________
Old 12-18-2016, 01:06 PM   #7 (permalink)
Sport's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Do you have an engine block heater installed? They are recommended anytime a vehicle is being regularly used in sub freezing temperatures. I think you could get a simple one for ~$50.
__________________
1999 Ram 1500 5.9L 4X4 Sport
Transgo Shift Kit, Off Road Y Pipe, Magnaflow 14" Muffler
Sport is offline   Reply With Quote
Old 12-18-2016, 01:30 PM   #8 (permalink)
crazy_luck's Avatar
Ram Year: 2013
Engine: 5.7
Default
Yep, there are OEM variants for the 2nd gen Ram for about $50 that replace a frost plug.
Or, you can get a universal magnetic one that just attaches with a heavy duty magnet to the oil pan or block. Down side is you have to partially crawl under every time, but it's cheaper and just as effective.
https://www.amazon.com/Kats-1160-300...c+block+heater
__________________
Old 12-18-2016, 07:23 PM   #9 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
I'm in the same -26 bullshit on the other side of the state. 50/50 is good for -20 and with the way the wind picks up, on a full full i go 1 jug 100% ethylene glycol and do the rest 50/50. Never have an issue
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-06-2017, 11:45 AM   #10 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Well, the negative wind chills have returned, however oddly the problem has not returned. The only difference is that I've been pumping Quik Star gas rather than BP. No idea if this could have been a factor or not. Guess we'll see if everything stays okay.
One thing's for sure though. I either need a different battery or a new starter next year. I've got a brand new O'Reilly's Super Start Extreme rated for 770 CCA and it really struggles to turn the engine in these temps. I don't expect a battery to be as strong in -20 as it would in 85, but I'm honestly concerned that I'm not going to get many seasons with this one before problems start. Or perhaps my 20-year-old starter has just become such a dog that it's making things harder than they need to be?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
84 Dodge Ram D100 hard start 2 nd starting Jim Robbins Engine & Performance 4 06-05-2016 09:58 PM
Hard starting? redmon42 Engine & Performance 3 09-14-2015 11:36 PM
Hard Starting, Misfiring and Bucking BoostedGS Engine & Performance 18 09-05-2014 10:50 AM
Hard time starting... Bigboytoys Engine & Performance 7 06-24-2013 11:51 PM
5.2 Hard Starting ktm1217 Engine & Performance 24 06-09-2011 04:42 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
