positiveimpakt
- Mar 7, 2016
- 8
- 1
- 1998 1500 4x4
- 5.9 360 Mag
Hi guys name is David I have been working with a couple guys on another dodge forum trying to iron this mess out figured I would give it a go over here.
98 ram 1500 4x4 5.9
symptoms
whirles over 5-10 times almost killing the battery, smash the gas pedal to get it to start. once running air idle control intermittently opens sucking HUGE amounts of vacuum and leaning the motor into a stumble. eventually it will close the valve and level off. also snap throttle will tell it to close or it will reopen fairly quick. I get power surge issues occasionally if I hop in and start driving when she is cold.
<a few small things to note..>
I had a couple injectors that wanted to leak they took allot of tweeking to get the system to dry up.
if I back out the screws on the fuel rail enough so the injector to leak a little it seams to semi cure the starting issue?
also if I shut the truck off and immediately crank it again it will fire right up. if I wait 10 mins its back to cranking the hell out of it even if the motor is warm.
I was showing a misfire code on cyl 3 and an 02 sensor the codes seem to have cleared them self's.as cel is off.
is there a torque spec on the fuel rail that would effect like a gap on injector?
if i didn't know better I would say im over tightening the rail sinching off fuel supply to one side of the motor then i loosen it and it seems to fix it minus leaky injector lol. scratch head!
Things I have done since this problem started...
plugs
cap
rotor
fuel pump
all 3 sensors on the intake keg..
new O rings
tested signal on all injectors
replaced plenum and intake gasket sets
new stat
water pump gaskets
and timing chain and gears
all fuses are good
things I am considering
bad PCM
Bad O2 sensor
I have a small pin hole leak in my filler neck going to the tank. possible air ration happening in the fuel pump? then its pushing 93 octane soda to the rail and confusing the hell outa pcm?
I pulled all the plugs back out today after putting 100 miles on them with the truck running like this and all plugs are clean.
also once its rolling down the road it runs great.
no noticeable gas in the oil levels good oil clean and thick!
maybe purge vavle charcole system thingy I know nothing about?
(wish i could rip it off and toss it in the trash can!)
once more little side note I purchased this truck a bout a month ago.
when I got it it fired right up even sitting in the winter battery was dead we had to jump it so I know prev owner did not running it before I got there.
I drove it like a baby for 2 days maybe an hr or 2 per day then all this crap started. prev owner has the o2 sensor past the cat out of the pipe?
looks like he had exaust work done and they put the wrong size fitting in for the o2. but like I said this truck ran amazing for a couple days.
any ideas? also if you see anything in my list you would rule out right away please let me know. this problem is costing me some money and a TON of time. Thanks in advance David aka Positiveimpakt
98 ram 1500 4x4 5.9
symptoms
plugs
cap
rotor
fuel pump
new O rings
new stat
water pump gaskets
all fuses are good
bad PCM
Bad O2 sensor
