Whitedog
Greetings. Truck is a 1996 5.2 98,000 miles, MANual transmission, stock. The only work I have done on it in the past months has been changing the track bar.
I don't drive this truck very often, but recently it has been giving me some fits. First start is perfect, but the second start is probably going to be a hard start. I have to step on the loud pedal and hold it and feather it to get it to start, then if I don't keep on it, it will die. Once it clears up, it runs fine.
No CEL, but I haven't checked for non OBD codes. I have a fair scanner and I should be able to get some good data, but I'm not sure what to look at or what to expect. I haven't had any troubles with this truck so I haven't had to work on it meaning I don't even know if it's drive by wire or cable so I don't know if it has an IAC valve. I'll have to check it out next time I get to the shop.
So, any advice? I searched the titles for "hard start" but didn't find anything relevant.
BTW, it is a hard start warm.
