Would it bolt up, probably. Will it do anything with the current hardware. . . .not much.
First you will need to replace your Kegger Intake or replace the crappy sheet-metal bottom with something substantially better.
Then you will probably need to replace your valve springs, especially if they are stock.
Stock fuel injectors might be able to eek-out a few more HP but if you want to make a decent amount more you will need to get larger injectors.
Then I would recommend a big intercooler, or water/**** injection if not running an intercooler (window washer fluid is a common thing people use). You are going to be pumping very hot air into an engine that's already very prone to detonation.
You then need to get plumbing for the oil which is not too hard and pretty cheap, a manual boost controller is also pretty cheap and easy to setup.
After its all installed you then need to make a new exhaust system.
Then the most expensive thing of all, you will need a custom tune. . .
In short
New intake Manifold | or replace sheetmetal on the bottom of the stocker and pray
Valve springs
Injectors
Intercooler + piping | or water/**** injection
Oil feed and drain lines
Replumbing the exhaust
Tuning
I would say at a minimum there is $2000 worth of additional stuff that needs to be done to make it semi-reliable.
