Thanks for the input, Stegs. Gears are one of those things that I know works but I always end up getting lost in the horsepower stuff.
It'd be kind of a win-win for me. My axles have over 180,000 miles on them and I'm fairly sure that I've got some light howling going on in the rear. Figure if I'm gonna have them rebuilt, it'd be the perfect time to swap ring and pinion. I'm on the fence between 3.92 and 4.10. While I'm at it, I want to swap the open rear carrier for a limited-slip because I'm tired of having to rely on the 4x4 every single damned time I have to take off in a little mud, LOL. I don't want to deal with tire chirping in the corners or screw around with an "air locker," so I figure a good aftermarket limited-slip will fit the bill.
A question that I do have is what kind of gear ratio does the front Dana 44 typically have? I'm wondering if I'm going to have to swap the gears in that to match the rear or if the OEM ones will be "close enough." I do know that the 44 has some weird stuff going on with it's geometry and you have to use thick-cut ring gears and such. Any input on that?
As much as I've toyed with ideas, I'm honestly thinking of just sticking the with kegger, screw the "kegger mod," grab some Gibson shorties and some Harland Sharp 1.7s, getting some gears and calling it good. Maybe swap in a "torque" cam from Crane if I can find a way to keep the compression pump-friendly. Sooner or later I'm gonna have to really satisfy my need for speed and finance a first-gen Viper or a big block Road Runner or something, LOL.
Thanks all for the input. I truly think that I'm finally coming up with a final picture of what I want from my truck: maximum low-end torque with as much mid-range as I can get away with and not having to bust the bank.
Oh, and fuel economy? Heh, if I was truly concerned about that, I never would have sold my 5-speed Accord back in the day. That car was solid as hell and got 28-32 MPG. I'm averaging 12 on a good day with the Ram and if I can keep it around that with mods, I'll be happy.
Also, on another note, why doesn't anyone make an Edelbrock Performer to run with MPI? Much more low-end than the Air Gap and still breathes well at mid RPM. I feel that THIS would have been a better base than the Air Gap for fuel-injected Magnum engines.
stock gears in your truck are probably 3.55. A good all around gear. Thats why they chose it.
Dodge knew on the off road edition ram's that they needed more gearing, so they went with 4:10 and a limited slip
I went from from 3.55 to 4.56 gears in my truck. I added a spicer limited slip while i was doing it. Of course all new bushings/bearings.
I would go with either a 4.10 gear or a 4.56. If you want max torque 4.56 is a great gear ratio, especially if your running over size tires or plan too
Here is where I would start on your truck: (unless you know how old this stuff is)
New copper plugs (champion or NGK)
good quality wires
new air filter
quality oil (i suggest rotella T5 synthetic blend 10w30)
quality filter (napa gold)
quality fuels (exxon/mobil/BP/Shell)
Id stay away from the mom and pop shops for fuel, they tend to buy cheap grades of gas. Visit
Home | Top Tier Gas Find quality fuel and use it. My truck runs better on 89 octane min, but i run 93 because of my tune
Easy and cheap stuff to do. Get the truck running as best it can.
Save up for the gears unless you have the cash to do them now
The cam is a good idea, but there is nothing wrong with the stock cam. I have heard good things about the RV cam
headers are a great idea, but only if you plan on a high flow exhaust (high flow cat and muffler)
Getting air + fuel in, mean you must get exhaust out!
From my experience, start with the basics, a good tune up WITH QUALITY PARTS is where you want to start!!!
DO NOT GET CHEAP AUTOZONE CRAP. Spend a few dollars more at napa and get good stuff
after that, gears are great! Here is a list of my mods on my truck
4.56 gears
spicer limited slip
upgraded valve body in trans
2200 stall converter
shift kit
check valve delete for trans
AEM brute force intake
SCT tuner by hemifever
trans cooler
magnaflow high flow cat (direct fit)
magnaflow muffler (single in/single out) stock replacement tailpipe (for better torque)
Mopar M1 intake
Way more than i can remember, but these stand out
I never touched my cam, throttle body, or exhaust manifolds.....ive looked into headers, still cant decide
I just dont drive my truck much anymore. Last year i only put about 425 miles on my truck....yea it sits alot!!!
I do miss driving it!!
