As long as we're talking airflow, any input on the factory heads? If one were to combine an Airgap/M1 with a beefier cam, would the heads be a significant bottleneck? Silly question I know, but I'm just curious as to how much of a bottleneck they would be. I ask simply because pretty much every head that I see which flows significantly more than OEM uses 2.02" intake valves and I'd rather stick to 1.92" for the sake of my low-end grunt. Not to mentioned they're damned expensive, LOL.
I've got OEM-spec replacements right now. They've got thicker castings between the valves to eliminate, or at least alleviate, cracking which is where the factory ones like to crack it seems. Both of mine had at least one crack in that very spot. They aren't the EQ ones though, which I've read flow slightly better than other OEM-spec replacements.
I wouldn't bother swapping cams without the use of aftermarket heads.
The stock heads crack, and the factory springs are terrible.
The springs can be replaced, but aftermarket springs can fatigue and break the factory 2 piece valves.
The 2 piece valves can be replaced, but then you're hundreds of dollars into factory heads that still crack, and don't flow well .
Even if you ignore the above insight and swap cams, you might pick up 10-15 whp at peak, but it comes at the expense of bottom end power. You end up with less average HP across the curve. This might work in a lightweight truck that is class-restricted to stock heads for racing, but in a heavy Ram, it is counterproductive. I never understood the logic in wanting to "sound cool" without having the power to back it up. I really try to shy away from tuning those types of setups, even if the customer says they dont give a flip about power output, they always end up disappointed anyways.
I had a customer about 18 months ago who I had this conversation with. Big cam, stock heads, full bolt ons. He was insistent it would make big power. I had retuned it from another popular SCT tuning vendor and he said it ran great after I did my thing. Get to the dyno.....it made 261 whp. He was furious, but I warned him ahead of time that without aftermarket heads, or a ton of work into the OEM heads, that's about as far as it would go. Had he bolted on a set of aftermarket heads- any aftermarket head- he would have made 320+ wheel without issue.
The valve size is far less of an issue than camshaft selection.
