Stegs
- Apr 7, 2014
- 301
- 137
- 1998 Dodge Ram 1500 4x4
- 5.2L 318 C.I.
You will experience less low rpm tq loss with the M1, instant throttle response, the M1 takes to other performance parts great, as I said in my other post works great from idle to WOT. The M1 is a true 2bbl MPI single plane intake, the F1 is a 4bbl dual plane carb intake that uses an adapter plate for the TB and it has had injector bungs cast into it. The M1 was built and flowed for the Magnum motor nothing else.
Edit; As for the Kegger mod either intake will get better results.
great info, very informative! thank you so much
from what ive read here and other forums it sounds like either one is a better choice than what i have now (stock)
by the time you add up everything for the mopar m1 and the huges there is a 3-4 dollar difference...not much at all
I like the idea of the mopar m1, keeping it mopar and having a place for the IAT
but on the other hand, the hughes kit flows slightly more air, and I can have the IAT moved to my cold air intake pipe which will give better readings...making maybe a few more HP
sounds like its kinda personal preference to me....ive read good things here about the m1, but ive read good things on other forums about the hughes
tough choice to say the least
