I think my fuel pump went out
e_hartzell17
Ok so I started the truck and let it idle for a rough 30 mins or so then I got in it hit the skinny pedal on the right a little and boom she died, when I went to go crank it it didn't start back up, so I left the key on and got out to hear like a hairdryer sound coming from my fuel tank and I'm pretty sure my fuel pump went bad not positive though. Any body ever have this happen if so I could really use an explanation haha.
dudeman2009
Magnum 360
Is their fuel in it? The gauge may be wrong.
Try hitting the tank with a hammer, or getting a fuel rail pressure test kit, you can rent them from autozone.
It should only prime for 5 seconds or less, usually if it tries to prime longer than that, it indicates a problem. Is there any fluid leaking?
dapepper9
Iowa/Nebraska Border
5.9L V8
Whine from the tank is a good thing. It means the pump is at minimum trying to work and is getting signal. If you hear it whine, check rail pressure for about 50psi +/- 2psi. Good pressure, pump whines, likely going to be spark
texasrebel
5.9 Magnum
Mine went out about a year ago. Found easiest way to access it since it had a full tank, was to lift the bed. Dropping a full tank isn't fun.
Sent from my SAMSUNG-SM-G870A using Tapatalk
e_hartzell17
e_hartzell17
Well luckily for me I'm under a 1/4 tank but it's weird cuz about 2 hours after I though she went out, it started right back up no problems
texasrebel
5.9 Magnum
Hm. Kinda odd. Might still want to get someone to test the system.
e_hartzell17
e_hartzell17
Yeah for sure another good thing though is wishing the next few months I'm putting a turbo setup on the truck so new fuel pumps going in anyway
texasrebel
5.9 Magnum
Turbo setup? You have my interest.
e_hartzell17
e_hartzell17
Lol yeah gonna be running a remote mounted hy35 cummins turbo tuned with sct with a warlbro 225 fuel pump, ford cobra 39# injectors, 8psi wastegate and a mild comp cam
texasrebel
5.9 Magnum
You got any idea what kinda power boost your gonna get? IIRC, the stock internals can only handle around 9lbs up top before the heads start floating and around 12 on the bottom end. Got a build thread for this?
e_hartzell17
e_hartzell17
I was thinking somewhere in the +100hp range started a thread called 5.2 magnum turbo just kinda threw around the idea not taking it seriously cuz let's face it if the motor won't blow the tranny will but decided to say **** it and went for in bought everything I will need now just waiting for the time to do it
crazy_luck
Minnesota
Try cycling the key from OFF to RUN a few times - it will pressurize the system. If it starts and stays running, you have a pressure regulator issue or a plugged filter. If it stalls out after a few minutes, the pump is dying. Drove my last 2nd gen with a failing pump and regulator for 6 months - had to cycle the key about 10 times every time I started it (regulator). If it sat at idle, it was fine but if I floored it, it'd die (pump).
Also, running as low as you are on fuel, that might be part of you problem - your gauge may be off to the point you don't actually have enough fuel.
e_hartzell17
e_hartzell17
Never even thought about that
texasrebel
5.9 Magnum
I'll check it out. I'm curious to see how it'll turn out.
e_hartzell17
e_hartzell17
The day I got the turbo in the mail
texasrebel
5.9 Magnum
Ooooo. Love that color. You oughtta post a build thread somewhere for the whole truck. Thing looks sweet.
e_hartzell17
e_hartzell17
Thanks man took a while to get it there but it was all worth it
texasrebel
5.9 Magnum
1500 or 2500? Wheels make it hard to tell, but I've never seen a 318 in a 2500.
e_hartzell17
e_hartzell17
1500 with a 3.5" leveling kit up front and stiffened suspension in rear
texasrebel
5.9 Magnum
Nice. This is mine. 1500 4x4 with the 360 and a 3 inch lift on 33s. Really want to repaint it a green like that or a nice orange.
amdwilsns01
