DODGE RAM FORUM - Dodge Truck Forums
DODGE RAM FORUM - Dodge Truck Forums (http://www.ramforum.com/)
-   Engine & Performance (http://www.ramforum.com/f61/)
-   -   I think my fuel pump went out (http://www.ramforum.com/f61/i_think_my_fuel_pump_went_out-96191/)
e_hartzell17 01-06-2017 05:13 PM
Ok so I started the truck and let it idle for a rough 30 mins or so then I got in it hit the skinny pedal on the right a little and boom she died, when I went to go crank it it didn't start back up, so I left the key on and got out to hear like a hairdryer sound coming from my fuel tank and I'm pretty sure my fuel pump went bad not positive though. Any body ever have this happen if so I could really use an explanation haha.
dudeman2009 01-06-2017 05:39 PM
Is their fuel in it? The gauge may be wrong.
Try hitting the tank with a hammer, or getting a fuel rail pressure test kit, you can rent them from autozone.
It should only prime for 5 seconds or less, usually if it tries to prime longer than that, it indicates a problem. Is there any fluid leaking?
dapepper9 01-07-2017 12:15 PM
Whine from the tank is a good thing. It means the pump is at minimum trying to work and is getting signal. If you hear it whine, check rail pressure for about 50psi +/- 2psi. Good pressure, pump whines, likely going to be spark
texasrebel 01-07-2017 11:36 PM
Mine went out about a year ago. Found easiest way to access it since it had a full tank, was to lift the bed. Dropping a full tank isn't fun.
Sent from my SAMSUNG-SM-G870A using Tapatalk
e_hartzell17 01-07-2017 11:38 PM
Well luckily for me I'm under a 1/4 tank but it's weird cuz about 2 hours after I though she went out, it started right back up no problems
texasrebel 01-07-2017 11:42 PM
Quote:
Hm. Kinda odd. Might still want to get someone to test the system.
e_hartzell17 01-07-2017 11:43 PM
Yeah for sure another good thing though is wishing the next few months I'm putting a turbo setup on the truck so new fuel pumps going in anyway
texasrebel 01-07-2017 11:45 PM
Quote:
Turbo setup? You have my interest.
e_hartzell17 01-07-2017 11:47 PM
Lol yeah gonna be running a remote mounted hy35 cummins turbo tuned with sct with a warlbro 225 fuel pump, ford cobra 39# injectors, 8psi wastegate and a mild comp cam
texasrebel 01-07-2017 11:49 PM
Quote:
You got any idea what kinda power boost your gonna get? IIRC, the stock internals can only handle around 9lbs up top before the heads start floating and around 12 on the bottom end. Got a build thread for this?
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
SEO by vBSEO
vB.Sponsors
