ADudeOnSkis
- Oct 28, 2014
- 396
- 226
- Truckee, CA
- 1999
- 318/5.2 Magnum
1999 1500 4x4 318/5.2 manual
When I brought her home she had a bad downstream o2 sensor and a gas gauge that jumps to full on startup buy slowly comes back down to show E. It would start perfectly on 2 or 3 turnovers if it wasn't cold out, maybe 5 on cold mornings. Replaced o2 sensor and MAP sensor (because I'm an idiot, long story but it didn't need to be replaced), my CEL went away.
Now what I'm noticing is when I let her idle for more than about 7-8 minutes, she will drop down in rpms (I don't know an exact number because all I have is an idiot light, no tach), sputter, and then I hear what SOUNDS LIKE a vacuum leak, and then it revs itself back up to a high idle for about 30 seconds and the suctioning/vacuum leak like sound goes away, and then repeats this whole process. I haven't gotten her to die yet. When I get driving, if I stay in my power band (again, no tach, so I don't know where that is) or cruising in 3rd 4th or 5th, she purrs and runs fine. But if I let her get down in revs in 1st or sometimes 2nd, it is a little rough at times, it almost feels like the trans/clutch trying to engage (but I'm pretty sure it isn't). Where this is most noticeable is on dirt roads where I'm in 2nd gear trying to stay around 5-10 mph.
This morning, after researching the plenum gasket problem even more, I pulled off the airbox/cleaner and took a peak down into the manifold. Yep, oil, but definitely not Lake Exxon. I then reattached my airbox/cleaner and fired her up to listen to the engine while with the hood open as I hadn't done that yet, and nothing. Runs fine. A little quick in the normal fluctuation of idle speed, but it wasn't drastic and it certainly didn't sound like it was about to take a ...
The only thing that changed was I didn't clap down the box/cleaner assembly as tight as it was before. Nothing else. I'm letting her cool off for a while then I am going to start her up again and see what happens. Any thoughts as to what, if not the plenum gasket, could be causing this? I really hope it isn't, because I do want to upgrade my intake in the spring and don't want to drop the money and my time into replacing the gasket/plate right now.
Any help and insight is greatly appreciated! And yes I read DDs sticky... great info but I'm still wondering...
