1999 dodge ram 1500 V8 5.9L over 200k miles on it. I had my cat. replaced about a year ago, ever since then I have been having issue's with it wanting to die if it idle's to long and I will hear a hissing noise like a vaccum hose's is off (have looked at them and they all look good and tight) and a high fuel smell. Today it flat out refuse to start I had a "No buS" apper where my odometer read's. So I turned the key to the on position and after letting it sit for a min .my gas gauge and my voltage meater was reading again. (like it reset or something) So I tried to start it. It started but wont stay started till about a mile of driveing then I can let off the gas and not worrie about it dieing. unless I am waiting at a light to long. Also the past week I have been having my odometer go down to zero then back to where it supposed to be, or jumping all the way to 120. also have had the abs and brake light's come on while this happen's. (not every time but has started the past few day's) I have replaced my fuel pump and fuel filter since it is built into the pump! I have done the spark plug's and wire's, as I mentioned above had the cat replaced. I have cleaned my injector's with seafoam. I am getting ready to replace my battery cable's and manually clean the injector's. Oh and I have notice that my light's will get bright and then go back. Any help would be nice as I am about at my last straw.
