Jstraubel
- Sep 18, 2014
- 2
- 0
- 2000
- 5.9 magnum
First off I've got a 2000 ram 2500 4x4 with only 60000 miles it odviously doesn't get out often but I'm starting to notice a few things that I can't quite put my hands on
1 erratic idle (intermittent) every once in a while when it's in park it will start chugging and choke itself out and stall, it's only when it's parked and idling? Iac and tps have been changed.
2 Noticed a exhaust leak is there common issues with this year of truck sounds like it's up by the motor don't no if it's the connection to the manifold or the manifold to the head I can't see any black streaks indicating its the manifold to the head?
2 Oil leak not to bad but it's getting annoying any common problems with the oil pan gaskets or is it normally the rear main seal? I can see oil on my oil pan dripping from behind the motor doesn't appear to be coming out of the bell housing but road wind puts it all over the place
Thanks in advance for the help
