E4ODnut
- Oct 21, 2016
- 31
- 3
- Gibsons BC Canada
- 1995 Dodge Ram 2500 4x4
- 8L V10
New purchase, '01 2500 Magnum 5.9, about 250,000 KM. Has an engine noise, a "clack", more like a knock than a lifter tick. Previous owner had the truck for about 1 month, previous owner to him about the same. Both said the truck came with the noise and didn't get worse.
Doesn't use oil. Oil pressure is good according to the stock gauge.
Starts and runs fine. Idle is good with no noticeable miss, but doesn't have as much power as I would have thought it should have.
The noise appears after about the first 5 seconds or so after start up and gets worse as the engine warms up. It is particularly noticeable at idle.
A mechanic's stethoscope shows it loudest any place on the oil pan.
Second loudest would be either rocker cover.
It is almost impossible to determine if it is louder near the front or the back.
Not particularly noisy on the timing chain cover. Without the stethoscope it seems to be a bit louder toward the front of the engine.
Pulling one plug wire at a time does not change the noise, so I don't thing it is a rod bearing, wrist pin or collapsed piston.
The noise seems to be less at revs above idle, but hard to tell for sure.
An interesting observation is that if I crack the throttle, the noise disappears for an instant but goes "clackety clack" a few times just as the engine returns to idle.
I'm suspecting the timing chain, but would like to get some opinions before I commit to pulling everything off to get at the thing.
The Check Engine light is on. The previous owner told me the codes are:
P0138 - O2 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0442 - Evaporative System Malfunction, Small Leak
P0445 - Chrysler: EVAP Large Leak Detected Conditions
I don't know what the symptoms of these codes would be or what the results would be, but I doubt they have anything to do with the noise.
Thanks.
Thanks.
