Need some advice.... I have a 2002 dodge ram 1500 4.7. Have a missfire on the #8 cylinder. I have replaced all coil packs, spark plugs , wires, o2 sensors and injectors. I have had a compression test done on the #8 and its fine. While holding key over truck will crank one time then stop. If I disconnect the negative terminal and connect it back it will start right up. I can drive all day no problem but early the next morning is the same Problem and the check engine light is back on. Anyone else have this issue?
