missing at 3k really bad.
johnMZ24
I have a 98 dodge ram 1500, 5.2 5 speed. When goin high in rpms at 3k exactly the truck missing and backfires really bad. But continues to keep goin up in speed and rpms, just misses bad. I cant figure it out. I have new map, tps,iac, cold air intake, headers, highflow cat and flowmaster, new o2 sensors, new plugs and wires, tb mod, 180 degree thermstat. All done about 4 months ago. Just started doing this last night. Any thoughts ?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I say do a compression test and make sure the plenum isn't blown.
J
johnMZ24
The plenum was blown when i first bought it last year just never got around doing it yet. But il have to def do a compression test.. it runs and has plenty of power exept in 3rd gear 3k rpm.. in first n 2nd i can go to 3500( i never go over 3500 ) and it dont miss at all.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
It's possible your front O2 sensor is fouled out already from the burnt oil from the plenum.
My money is on plenum issues.
J
johnMZ24
Im guessing ya cant take the front o2 and clean it up a lil can ya? Imma take it off after work n have a look at it.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Nope, unfortunately once it's fouled up, it's done. I would take it out to see how bad it is though.
J
johnMZ24
Im almost on E now, imma try n see if i put 89 in it if it will still do it. If it does, il do 93 this weekend. But i took the front 02 out n this is it. Its only couple months old. No codes at all besides target idle not set( from day 1 but check engine light isnt on, its from the plenum gasket. I idle at 900rpm and yes the cel does work).
J
johnMZ24
So it still misses with 89 in it in 3rd gear 3k rpm. I noticed it misses mid to full throttle. If i feather the gas it wont miss at all or isnt noticeable.
J
johnMZ24
J
johnMZ24
Found the problem. One of the sparkplugs where gummed up real bad, replaced now no miss. Thanks for the help
lasse452
