meistermash
Well friends, some one or thing has been stealing my oil.
I did the Plenum fix already.
The missing earl issue has just cropped up.
Been using synthetic the last two years.
What could be the likely culprit?
Valve guides?
It isn't leaking out.
New issue so the exhaust isn't oily yet.
Cat ran off to be with bezzelbulb so it can't be plugged.
Pcv line has been located to the right side of the Plenum.
Three back spark plugs on the passengers side do appear to be a bit oily but not real bad.
Can a vent problem cause an issue?
01 5.2 millage 105,000
Reason PCV was relocated, Plenum swapped out for older model I presume, with Plenum plate installed. More ports on the other side.
Also seems to need cranked a few times where as before it would just fireup.
Valve guides?
