korby05
Couple of things to ad here. If you mod the kegger you might just as well get the M1 intake as the modded keg takes about the same other mods to keep the lower end tq as the M1 does and you still have the pos plenum plate in play. The aluminum plate is not a end all be all fix, they do fail again we have seen this happen.
On my motor I still use the stock tb, I have a BBK 52mm for it and have only used it three times. Its great after 3000+ rpm but does nothing for bottom end tq.
So by getting the M1 it would eliminate the plenum problem all together? Which truly is what I want. I don't want to ever have to go back in to replace a part that I've already replaced unless it is something that is prone to wear out (shocks,ball joints etc)
