MillenniumFalcon
- Nov 9, 2014
- 7
- 0
- 1997
- 5.9Magnum +.090
Got a 97 3/4ton 4x4 with the 5.9 magnum bored .090 over and the light duty NV4500 5speed. Truck is sitting on 285/75/r16s with alloy wheels and has 4.10 gear ratio. The odometer reads 354,000 miles on it. I bought from a buddy I trust very well in HS a couple of years ago. He said the guy he bought it had the motor and trans rebuilt.
Well they both run great sort of. The trans is in perfect shape because I have taken it off after I blew the intermediate shaft and replaced that. All of the syncros and gears are in great shape. The problem is the motor has no balls past 50mph. There is no proof anybody has that the motor has been rebuilt. But the oil pressure is solid even after long drives and it idles and drives great. The truck is a regular cab long bed and has a grille guard (not front end replacement) and a Ranchhand rear bumper. I can burn the tires in 1st through 3rd gear without any problem if I want to. But once I shift into about 4th and get up to highway speeds I can stand on the pedal and the truck is awfully slow. I know the heads and larger tires have something to do with this but they offset each other and the truck doesn't weight much, only about 5400lbs.
I've been lurking on here and seeing that maybe the plenum has spewed some oil and it has maybe clogged up the cat convertor. I don't think that's the problem because I haven't noticed any symptoms of the leak.
I'm about to get the basic beginner mods like a CAI, programmer, long tube headers and an exhuast. I have some questions about pepping the truck up and the exhaust setup.
First off, I want the best performance exhaust I can get and I don't care about any legalities either. This obviously means no kitties and no muffler, but do I need short headers or long tube? And I think I need x-pipe setup somewhere around 2.5" but I'm not sure.
Second question is, once I get the exhaust, CAI, and programmer on how much of a difference is it going to make in the powerband? I'm assuming I need the SCT custom tuning, but I just want the best balls to the wall power I can get from that.
If the plenum is bad I'll go ahead and do that and just get a replacemnt intake. Also how much am I looking at to get a decent set of heads and a low powered cam for my truck? I can do all the work by myself except for exhaust.
