Ryan012500
- Mar 6, 2014
- 8
- 1
- 2001
- 5.9
Just put a reman 46re into my 01 2500 with 124000 miles 360 motor. After installing new trans the truck seemed sluggish.after buying a lot of sensors it feals more like the the engine is fine but the transmission is not grabbing properly. I Adjusted TV cable so that all shift points are right as they should be according to the packet that came with the trans. Install went smoot I filled the torque converter up with fluid before I put it on. Fluid level is perfect and smells good not like it was burned. also replaced all trans cooler lines and radiator and trans cooler and took out the check valve.am getting a check engine light the code says o2 bank 1 sensor 2. Don't know if this could be a part of the problem.
Here is a list of work I have done to the truck in trying to fix this
Took off throttle boddy cleaned the best I could get into intake manifold.
Cleaned throttle body
Put new iac valve
New throttle position sensor
New map sensor
New cold air intakeb
New upstream o2 sensor
New catalytic converter with 3" in and out
New downstream o2 sensor
3" pipe that goes out about a foot and ends between cab and bed I ordered a black flowmaster super 44 3" in dual2.5" out and I'm running it out the back to the sides right under the back bumper.
Did nothing to fuel system
Put new Njk spark plugs
New crank position sensor
New speed sensor on rear diff
I also put in a computer out of a 99 ram 1500 with a 360 and a 46 re just to see if it made a difference and the motor ran a lot more powerfull but as soon as I put it in my trans temp light and o/d light came on think it's because 99 and 01 trans have different sensors because the truck was cold. So I ordered a new computer and I'm waiting for it to come.
Also when I changed the down stream o2 sensor the old one smelled a little like gas
All this was done in the las week I'm running out of ideas im thinking maybe the bands wher not adjusted properly from the reman any thoughts would be great I know nothing about transmissions and I don't want to take it to the granny shop if there's somthing I can doo
Put new iac valve
New map sensor
