frustrated86
- Sep 26, 2017
- 1
- 0
- 1995
- 5.9
New here. Some history on problem before no start. Engine would shut down at every stop or idle without foot on the gas, progressively got worse. Replaced multiple parts now showing low voltage with no start, check engine light flashing. Now, heres what we tried.(some general maintinence) New gaskets on transmission and manifold, new battery, new spark plugs and wires, new alternator, new starter, new egr, new fuel pump, new rollover valve, new refurbished injectors (all working) new coolant temp sensor, new throddle body and cable, oxygen sensor, new crank shaft sensor, new throddle sensor, all new fuses and relays, new alt fuse, new ignition, ignition module, new power door lock, pcm tested no codes,new brake booster, new battery cables, new cat converter and a few more sensors. Help please. starter engages, have fuel pressure at rail. and pcm restart after every part. nuthin.
