Mohpar
46re, just started at my new job and it's a solid 35 miles one way trip mostly highway.
Well my problems started after I installed my shift kit - TFOD HD2 - but the truck kinda was weird in OD to begin with
At low speeds approaching 40mph, it tries to shift from 1-2 very quickly and goes back and forth 1-2-1-2-1-2 until I press harder into the gas - it shifts into 3rd and then I let off, it backs down and coasts into the last gear.
If I'm going 40-45 mph (which are most roads around here), it will shift to what I assume is OD and shake the truck a bit hard.
I hope what I am explaining is making sense, maybe I'll take a video on the way to work tomorrow and narrate what is happening.
Weird thing is with OD off there are no issues, it just stays around 2k RPM and revs pretty high which is to be expected.
Did I adjust something wrong? I know there is the white clip on the throttle body and the 1-2 shift adjustment on the actual trans.
Re-reading this, I'll for sure take a video tomorrow when I'm driving to work and it'll probably make alot more sense.
