Oxygen Sensor Help Needed Please
GT390
Magnum 5.2
I want to replace the oxygen sensors on my 2000 5.2 Sport 1500 4x4
my truck has no sensors in the stock manifolds,
it uses a total of two sensors,
one before the cat and one after the cat, it has a single pipe exhaust system
Every place / company I try list up to eight different part numbers to fit this truck, most also say it should have three, one in each manifold, and one post cat, my manifolds are stock and have a boss cast on each side for a sensor, but these have never been drilled or tapped to accept them.
even tried NGK/NTK tech help direct, and they are telling me my truck should have 3 sensors, one in each manifold and one post cat
Can anyone give me some help and or advise please ?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
can you get part numbers of the ones installed now and cross reference?
SmokedRam
Zephyrhills, Florida
For the rear, get Part# NGK 23099
I am finding a precat (left) sensor also by NGK...Part #NGK 23506
EDIT: Reason why I only listed NGK Part numbers...Bosch sensors generally SUCK for the most part.
