P0505 code
Uscgr04
My 99 1500 with 5.2, keeps showing code p0505, idles and runs fine. I've checked ohms between PCM & IAC plugs all under 5 ohms, no ohms between ground & IAC plug. Getting power at terminals 1 & 2. Pulled IAC turned key on no movement, Tried a new IAC no movement, so all signs pointed to PCM. Bought new PCM had it programmed to VIN, removed negative battery cable, installed PCM. Stealership wants $125 to troubleshoot! Last night removed both battery cables, hooked them back up, started it up getting same code! Anyone have this problem & what fixed it?
U
Uscgr04
Checked TPS, all within specs.
regularcab2500
Buffalo
5.9 Magnum
You need to recheck your wiring all the way back to the pcm. Unless you purchased an already faulty pcm, this is the only other possibility.
