MoparMagic'00
just like it says i have a p0720 pop up and it says the output speed shaft sensor is low voltage... so i picked up that sensor $20 plus tax at twilightzone and swapped it out... now they say there is fluid that pours out well mine didn't.. but the stick shows it full.. also it didn't change the code even after pulling the neg cable off for 10 mins.... checked the old sensor with my dmm and no resistance at all (bad sensor) all fuses are good and in place along with the relays... also new rear end abs sensor and still have code and brake-light and abs light on constant... Help me out guys...
