Any update?
The shop just called. The manifold gasket is blown. Also the truck is running on 7 cylinders and are running great. Just 1 isn't. He thinks its a piston or a ring. He said he doesn't feel that I need a new engine and he can repair this one. Now unless that 1 cylinder is egg shaped then we have a new issue but he said he just doesn't see that being the case since the other 7 are great. He said it will cost between 1250-1500$ I said go ahead and fix it. Thank you to everyone who has helped me.
It's more than likely one of the rear cylinders that has gone out. I would wager it's either a spark issue or a fuel injector issue on that one cylinder.
Odds are good that, that one cyld has a cracked valve seats.
Oh wow. You bought a truck that has definitely had some love put into it. You have a half ton with 3/4 ton truck axles on it. Good buy.
Looks so nice, wish I could 'like' it twice!
are you using sarcasm or being serious? lol I know the rearend came out of a 91 k3500
No, I'm serious. The amount of time and money to lift a truck that much and put Dana 60s in it is impressive.
Agreed.
91 K3500, GM 14 bolt rear end in it er? What gears ya runnin for such huge tires? I wouldnt have anything less then 5.38 for sure.
Could always put it in neutral, **** the front tires, jack the rear up, mark the drive shaft and one tire, spin it and count the rotations on the driveshaft.
*edit*
I just realized we're spamming up the info thread. Whoops.
*edit*
ROFL weve never done that before!
I know, right? lolROFL weve never done that before!
I apologize
