Zervun
- Dec 25, 2014
- 13
- 3
- 1999
- Magnum 5.9
Hello everyone,
In a nutshell, about a couple months ago my truck started running rough. Surging every once in a while and idle jumping - some minor times it works perfectly. I hit the forums and researched and think it's probably a plenum gasket going bad.
Today I am replacing the TPS and Idle Air Control Valve and reconnecting the cruise control line that has broken in half with some rubber hose - I did all the spark plugs/wires/cap/pcvs a couple weeks ago (which bizarrely caused my electric issues below) and all plugs looked great.
While I had the throttle body off I took pictures of the plenum and also the replaced throttle body from ebay that was ported - of note the ebay seller is gone which makes me a little concerned but it looked great when I put it on.
This is what things look like.
My question is - There looks to be some oil down there how long do I have or is that normal? I already have the aluminum plate and gasket set off ebay but the project takes a little time.
I am also having some electrical gremlins http://www.ramforum.com/f62/ac_fuse_blowing_truck_running_rough_when_one-104159/ but I think this is unrelated to my idle issue.
Here is what my truck is now.
- 2001 Dodge Ram 2500 5.9
- 66k miles (yes that is correct owned by my dad and now me)
- DODGE JEEP 52MM BORED PORTED THROTTLE BODY MAGNUM 318 5.2 360 5.9 1992-2003
- ( 261861377268 )
- Engine at idle surges to about 1500 - 2000 RPM at startup - figured this was a plenum issue, bought Ebay plenum and all the parts, not replaced yet as I didn't realize AC bracket was mounted to manifold
- This weekend changed out Dist, Dist internal, spark plugs, spark plug wires - note WTF did dodge put the Dist in the back that far under...
- Replaced battery as ABS was clicking after I reconnected old battery and battery was old
- Replaced PVC valves
- Noticed 140 amp alt fuse (fusible link) blown - due to cluster not working, AC fuse blown, and cluster gauge fuse blow - replaced all - AC fuse blows every time I turn it on, others are ok.
