Silver Tex
- Nov 12, 2013
- 62
- 7
- 1999
- 5.9
Hello,
I'm going to repair the plenum on my son's (new to us) 99 5.9L Magnum - 158K on the clock. The site has provided great information and insight. I appreciate that.
I thought while we were in there and at the suggestion of the plenum sticky, we'd swap the water pump and timing chain.
Question 1: The timing cover has 2 bolts that interface with the oil pan. What is the chance I have to pull the oil pan to complete this work. I'm thinking I can loosen the bolts and lower the pan sufficiently to remove/replace the timing cover. If I end up having to pull the pan, the manual states the motor mounts have to be unbolted and the engine lifted...yuck!
Question 2: I have a cam shaft position sensor, but it was such a chore just to change out cap/rotor, I'm thinking I'll put it in while the manifold is out if for no other reason than I have good access to it.
Question 3: What are the thoughts about mod's to the stock manifold, runners and injector ports? Have been doing some reading about it.
Generally we are looking to achieve a sound running truck that gets the best mileage we can squeak out it.
Went with recommendations in the stick - Hughes aluminum plate kit; 180 degree SS t-stat; gates water pump; cloyes double roller timing set (gaskets, crank seal included); Fel Pro gasket sets. Already did the wires, rotor, cap - all the hard way. Will change out the oil sending unit while the manifold is off.
Any thoughts would be appreciated.
Thank you,
Scott.
Thank you,
Scott.
