rodbuilder
- Jul 23, 2016
- 3
- 0
- 2002
- Cummins
Would someone in the know on transmission rebuilding please help me..............
PLEASE READ CAREFULLY -
I have a 2000 Dodge quad cab with the 5.9 Cummins in it and just had the transmission rebuilt in it, at a shop with 17 years of experience. It was supposed to have a new single disk billet converter and a new or rebuilt ($400) valve body. It's also supposed to have a manual flow valve (?) in it and that special snap ring that everyone installs. Beyond that, do NOT ask me what's in it, because I simply do not know.
The truck is bone stock with an Edge Comp programmer. The programmer is OFF in all of the following actions.
It's been to the guy's shop twice now and here's what it's doing............
The new trans now has right at 250 mile on it - 114 miles of that under a small load and the rest with no trailer at all. NO miles over 60 mph!!
Taking it easy through the gears it's shifting into 2nd at about 32 mph. It shifts ok through 2nd, but when it goes into 3rd and 4th gear, loaded or unloaded, it revs way up and finally goes into gear.
When it's under a light load with my 4000 pound tilt bed and a 3500 pound scissor lift and on cruise control....... when it hits a small hill in overdrive it revs way up, kills the cruise control and requires you to hit the "resume" button again!
Also, loaded or unloaded, the truck surges down the road - kind of like a wire is loose or something.
I just got off the phone with another transmission guy near me who said it sounds like it's "neutral flairing", and that if this is the case he would expect the builder to pull the trans all apart to look at the bands and clutches as they can be damaged REALLY quick.
Quite frankly I am REALLY hot about this. I laid out over $2500 to have this trans done right and nothing is right about it, and I don't want to drive it or he's gonna tell a judge that I'm the one who messed it up by driving it.
The guy told me before I went and got it for the 2nd time that he thought it might need a TPS sensor, but the truck has no check engine light and it already has a fairly recent TPS in it. So if there is there's no code showing why does it need a TPS?
Right now there's only 250 miles on the rebuild job.
I don't want a $2500 piece of crap that's going to blow up on me in 20,000 miles, I want what I paid for!!!
Question: What needs to be done to this trans and what would YOU tell the guy who rebuilt it?
My sincere thanks for your experienced help on this.
