what are some quick and easy ways to check if a plenum has been done or needs to be done?? what are some other pre trip inspection stuff to look up before buying
Thanks for linking him up with the TBS. Just because you see oil in the plenum doesn't mean it is a gasket. On my 5.9 Limited Jeep I had oil in the plenum
& it turned out to be the PCV that was sucking it in. Changed that & used this link to check it. Very simple test.
