jonwalden68
- Feb 12, 2014
- 44
- 0
- 1999
- 5.2
I just got a 98 dodge ram 5.2 4x4 im the guy I got it from drive an hour to meet so I could buy it got it home I towed it back because I didn't have no one go with me to get I went outside to crank it and within 3-4 minutes it went straight to temperature handle on gauge maxed out and check gauge came on I turned it off checked for leaks no coolant leak and radiator full of coolant I felt too hose still soft and mostly cool bottom hose was a little warmer but not didn't feel hot enough to overheat. Let it sit a few mins still stuck on max temp looks like the previous owner just put on a new clutch fan and water pump doesn't look very old any ideas what it could be or were to start just don't want to run it hot? Please help I wait a little while like 4 hours went out to look it at again right when you first crank it the temp gauge doesn't stay on cold goes right up to 140-150 on gauge then within 5-6 mins it will be overheating according to gauge but radiator and top hose are not that hot bottom hose is a little warmer any help be great
