crazzywolfie
- Apr 6, 2013
- 16,431
- 3,192
- under the truck
- 81 93
- 5.2
i was wondering what you might suggest looking at on a 94 ram 1500 if it was randomly stalling. it seems like it has been getting worse to the point it has stalled out 4 times in 1 day. it generally seems to do it when the engine is idling lower. the IAC was replaced in hopes that it would fix the issue but it hasn't. even giving it gas after stalling does nothing so i know the IAC is not the issue. when it does stall you have to wait a minute and it usually fires up again. will not re fire up immediately. it needs about 10-30 seconds with the key off before it will refire. i am possibly thinking crank or cam position sensor but i would hate to have to swap out a crank position sensor and it not be the issue especially since it is in such a pain in the as spot to get at.
