Re-ring
jep79j
I was wondering if a 318 and a 360 re ring kit would be the same. Not boring or going bigger just freshening up the engine. Thanks in advance.
dudeman2009
Magnum 360
No the 360s bore is 2.3mm larger in diameter. You need the engine specific rebuild/rering kit.
Yeret
The Village Drunk
Under the hood fixing/breaking something.
5.9 Magnum
I'm pretty sure that the 360 also has larger main journals which kills my backburner dream of dropping a 318 crank in a 360 block to make a 340 (yes, I know bearing spacers exist, but they don't seem very trustworthy).
