Odd, It roughly idles in Drive at a stop, driving down the road is okay. Lack of power, Lack of fuel Eco. I get 220Miles on a 24Gallon tank? Ew.
Used to get 320?
Well, This is what I have replaced, gone over, checked and my symptoms.
Plugs, wires, Cap, rotor, all pullys, new intake gasket with plenum, new injectors, new intake filter, cleaned TB, New TB Sensors, new Intake Sensors, New Smog related Parts, New Water Pump, New Chain, New Timing gears, Compression is great, fuel rail receives Proper PSI. vacuum would be constant issues? New O2, New Cat, New Flowmaster exhaust system.
Anything around the motor you can think of, PCV, Only Pully I have not changed is the Alternator?
Symptoms - Rough Idle at dead stop in Drive, Or Park. Intermitint issue, Not 24/7.
Rough running feel.
Squeely belt when reved, Alternator Pully??
interfearence in sterio, When driving down the road, I can hear the subs beating even with sound OFF and Sub Selected OFF on deck. Still receives the hitts/ I could stomp on floor and it plays the stomp? I regrounded the Amp, Checked the Battery Grounds, those are good.
Bad Eco, Like I said above.
I have seen a lot of people posting on here about a similar issue. Never find out what it was exactly, Any idea's?
Could alternator possibly be going out causing strain on the pully and as well low voltage or improper voltage for the vehicle.
180k miles on truck
I did receive a Engine light for Injector malfunction.
Get this though, I had key turned over at gas pump for music and filling up. It started pinging that issue? Bad fuel pump? or regulator?
P.S. Truck was NOT started when filling up ofc. lol.
Just on ACC.
Used to get 320?
Rough running feel.
180k miles on truck
Just on ACC.
