RAMsport2001
- Oct 19, 2014
- 14
- 0
- 2001
- 5.2
it all started when I couldn't keep my truck started. It would start right up but as soon as you give it gas it would die right out, then wouldn't start unit I let it sit over night. Thought it was the crank position sensor, replaced with OEM but didn't fix it. after further diag decided to check the IAC valve and noticed it was all gunked up. cleaned it up and noticed a little difference, would still die with gas but not right away and it would start right back up. So I replaced the IAC valve with an A/M brand from NAPA. Runs and stays running. took it out for a ride around the block a couple of times and seemed fine. after letting sit for about an hr took it to the store, on the way there it started to loose power a little bit when I would give it gas (sounded like it wanted to stall, and made popping sounds). now every time I started it after about 2 mins it sounds like it wants to die out (makes almost a whistling sound) until I give it some gas then its sounds fine. Then occasionally it will try to stall out but doesn't. Any ideas?
