wayfastf150
- May 12, 2013
- 7
- 0
- 2000
- 318
Hey guys, I am new here but not new to rams. I had a '98 sport a few years ago, and just picked up a '00 with a 318. When I got the truck I pulled the codes off it, P0132, and P0135. I ran the truck like that for a few days, it didn't run terrible but idled rough, lack of power normal upstream O2 sensor problems.
I crawled under the truck to see how bad it was going to be to change the upstream, and found the sensor not plugged in. Thinking the PO disconnected it when it went bad, I put my OHM meter on the two white wires and got between 7 and 8 ohms. Ive read a good sensor is between 4 and 7, so I plugged the sensor back in and cleared the computer.
During the first test drive after about a mile on a 35mph road, the truck would start to bog around 1500rpms and feel like its about to stall. I can hear it popping also. If I back out of it and slowly get back on it until I hit the kick down it seems to clear up around 2500-3000 rpms. Its almost as if the plugs are loading up and need to be cleared out, or there is some kind of a governor kicking in.
Ive probably put about 50 miles on the truck running this way, it has never stalled out on me, sometimes it will idle smooth other times it idles rough. I am not showing any codes which a misfire should throw a code. In the 50 miles or so Ive driven it with it acting up, it has probably done it 5 or 6 times, and it happens randomly. Some times it clears right out others I have to work at it.
